Upgraded rear axles
Texas
I was actually getting some good info out of that last thread that was started by Pig but then deleted because of rules (rules, rules, everywhere there are rules:D ).
I am concerned about axle strength though it sounds as if the oem axles with the ARB set-up are strong enough to hold up to 37s and power upgrades.
Any comments?
Are the axles that come with the e-locker rear ends different then the axles on the non-locking rear ends?
I appreciate the info. I could search for that thread, but I will save my time if you could tell me that the same problem has not been evident with the use of an ARB.
It is not evident with an ARB. Sorry I dont know all of the technical terms but i'll give this a try. The rear eLocker has long splines on the short side shaft. This is becase there is this sort of sliding fork that slides over onto those long splines to lock the 2 sides together. The problem arises when the shaft twists, because it twists inbetween the diff and the sliding fork. So when you go to pull out your shaft you cant because its stuck twisted in there. Then you have to cut a hole in your housing and then you have to torch the slider fork to pull the shaft. This does not occur with an ARB, Detroit, EZ, Aussie, etc.
