update update
woody
Adulting: do not recommend
Staff member
Admin
SW Utah
A few things got done early this morning, and being completed currently....
Search: Sphinx is the new 'engine' powering it. Initial testing shows an 8x speed increase in search times.
Changed the webserver software from Apache to Litespeed. Finishing setups on that now. Litespeed is about 6-8x faster than Apache for serving pages.
Other minor tweaks have been done too, including many of the config files.
Hopefully, all smoothed out by noon.
I keep getting an error screen. This is what it says
Warning: require(/home/forum/titleimage/showthread.php) [function.require]: failed to open stream: No such file or directory in /home/forum/vbseo.php on line 1577
Fatal error: require() [function.require]: Failed opening required '/home/forum/titleimage/showthread.php' (include_path='.:/var/lsws/lsphp5/share/pear') in /home/forum/vbseo.php on line 1577
I'm various errors seemingly randomly.
still working thru things...as noted, should be smoothed by noon (no promises on what time zone tho...lol)
No problem man, just letting you know.
appreciate it - server is 'officially' on Litespeed now...will be working thru oddities this morning :)
for the record, just got the following when accessing Clubhouse
Code:
Fatal error: Out of memory (allocated 9437184) (tried to allocate 89 bytes) in /home/forum/global.php on line 106
loaded fine on refresh
https://forum.ih8mud.com/chit-chat-section/
Code:
Warning: require(/home/forum/titleimage/forumdisplay.php) [function.require]: failed to open stream: No such file or directory in /home/forum/vbseo.php on line 1577
Fatal error: require() [function.require]: Failed opening required '/home/forum/titleimage/forumdisplay.php' (include_path='.:/var/lsws/lsphp5/share/pear') in /home/forum/vbseo.php on line 1577
again, loaded on refresh
getting blank white pages too...got one trying to read this thread, hit refresh, got the 'out of memory' error, hit refresh, and got thru.
comparison:
R 5:15p - 1.21 1.32 1.53 | 1,036 Users Online (411 members and 625 guests)
F 9:45a - 0.79 0.76 0.71 | 753 Users Online (353 members and 400 guests)
smileys are displaying wrong too, intermittently
Look at the confused smiley in these screen captures from the same page, i.e. both versions were displayed at the same time on the same page. When I refreshed the page they were both the squished, blurry version:
attachment.php
attachment.php
tried a setting to 'fix' all image sizes...and that messed up EVERYTHING...need to go in and adjust a few dozen settings for it to work...
un-set for now...
