I have been trying to figure out for over a week now on how to fix the cdl and lockers so here is an update. First let me catch you up on what has been done and results:
I've been test driving my friends LC for a week and I tried to put in 4l and engage the lockers but no dash lights, no cdl and no axle lockers. He had justed used a week before.
Began to research on here for a solution and the first thing pointed to the cdl sensor. Pulled it and checked the switch and read some high resistance. I did the battery clean procedure on it and it then read a great 0.3 ohms. Reinstalled the sensor and still did not work. Did a lot more research and proceeded to pull the other two sensors (4l and neutral). Checked them and read some high resistance so i did the battery clean on them. Reinstalled these sensors and still no change. Once again began to do more research and beg for help (thanks guys). Went to my friends house and put all the rear seats back in so I could carry the kids. Then decided to try and tackle the 4wd issue. I busted out the fluke and test light and began to investigate. I used this site and it was great. Troubleshooting the Toyota FJ80 Land Cruiser Center Diff Lock (CDL) | Pacific Northwest Backroad Adventures
I got under the LC and had him shift into 4l but the actuator did nothing. Rechecked all fuses and then popped off the drivers kick panel. Pulled the plug from the trans relay and checked all the power feeds from the harness. GOOD!! Proceeded to pull the trans relay and got my leads with a 9v. I followed the relay test and it clicked each time and checked out. Then climbed under the Lc and tried to seperate the harness from the actuator but it would not budge. We gave up testing the actuator!! Fixed the tag lights instead. Went to leave and there those beautiful lights were shining (CDL AND ABS). Then turned the dial and both axles locked up. I was like holy crap finally. Never found a true fix but just started working. Maybe the trans relay was stuck and popping the 9v battery on it released the relay inside maybe. Maybe a loose wire on the actuator and when we were trying to seperate the plug we finally put it together tightly.. Dont know!!!
What you think fixed it??
Thanks for all your help on the subject for those who sent info and commented!!!!!
Man this thing is a beast once all locked down, I never realized how bad they were till i was locked down!! Looks like I will finalize the deal with him now!! All problems with the LC are fixed except when I mash the brake the cruise control cuts off and will not come back on till I power off the truck and then back on!!
