Unlocking for Passenger Side
Nashville, TN
has anyone else had problems not being able to unlock all doors when unlocking the passenger side door? the driver side works fins when turning the key twice
I think that's how it works by design.
If you turn the key once on the passengers side on mine, it will unlock every single door in the vehicle.
Sometimes it's screwy, so it doesn't unlock any but the passenger side.
Since the day I got it, it has always unlocked all the doors at once.
according to the fsm, all doors are unlocked by turning the key once on the passenger side
Does the owner manual confirm this? I'll check mine out later tonight if you haven't gotten a definite answer by then (I haven't used the key for entries in the last 6 years, FWIW).
Well, what chapter then; Body Electrical (BE), or...?
Or even: What else is discussed on nearby pages?
Help me out if you can; I really am curious. My 91 passenger door acts as if there are no electronics at all connected to the outside lock; just a mechanical locking/unlocking action of that door only.
Thanks,
Curtis
Curtis-
My DS door does the same thing as your PS door.. However, it DID unlock all doors once upon a time.
Maybe there's a bug in the 91's that Mr. T silently fixed for 92? :confused:
Does it on my 94 and 97. Don't know about 91.
Really? My '94 doesn't from the PS. It doesn't even sound like it is trying and they just don't unlock - there is no sound at all.
Any other '94's that with works on??
My 96 always opens all locks from the pass side if I can get the lock to turn that way. But the lock cylinder takes a lot of teasing to get it to turn to unlock at all. The switches work fine, but the mechanical lock is sticky. I have lubed it, played with it, even re-keyed it. It just doesn't like me. I use the drivers' side. Chivalry is dead in my truck! My wife is used to it!
My '92 opens all locks from the pass side as well as the driver's side. I had to use the VIN to get new keys made at Toyota, as the PO key only opened the driver's side door, and ran the ignit. The key wouldn't open any other door. New key works in everything.
i took the door apart and there appears to be a little electronic box connected to the door lock, so my guess is it is shot. looks like its time to get an inexpensive remote entry system
