Unkown problem with presure and Engine
Hot Springs
I have a 74 FJ40 with a F motor, when I first purchased it and got it home, the hood was up and the overflow stem beneth the rad cap, shoot coolant out 6 feet away, I had it at the shop replacing all fluids new Dizzy, all new hoses, water pump, and rebuit carb, and no problems, now the coolant shoots out, I removed the rad cap and can smell emissions in the coolant, there is no white smoke its not getting hot, so is this a cracked head or a blown head gaskett, this cruiser just looks for things to go wrong so I cant get it out on the trails,
Man that sounds severe!! I was going to suggest a block test.. but that would blow that thing out of your hand...Either a blown head gasket or cracked head.. you can pull the plugs, crank it over, and see what cyl. coolant shoots out of..to help pin-point the cyl in question.. then extract the head and go from there....
Sounds like it is overheating. I did not read thermostat in the list? If not the thermostat, then maybe a head gasket?
GL:beer:
Ed
Could try a radiator flush product, if its blocked the over heating will cause that to happen. However my money would be on the head. Try the simple stuff first, their are some products that will temporarily seal a cracked head / blown head gasket you put them in your radiator, but be warned if you leave them in too long they can do such a good job that they might start to constrict water flow through your radiator!
Get the rig pressure tested at a radiator shop and see what they reccon. Generally in my experience, you can find lots of things to blame but ultimately when the cooling system is pressurising its time to take the head off...
on the flip side, like all things with cruisers, once its fixed its fixed unlike the piece of sh*t Mitsubishi Pajero i used to have F**king useless B*stard contraption
pressure problem
Thanks for the heads up, I have not replaced the thermostat, but the upper hose get firm quick, also number 5 cyl started missing and then after 40 sec or so # 5 was ok, but still had coolant shooting out, maybe now is the time to think about a 2f or a V-8 job.
thanks for the help
Damn Man.. from your past post and this one .. seems you lean towards canned remedies??
Why stop wheelin till you have to, and if you read it i suggested my experience no matter what he does he is really only masking a problem that his going to ultimately have to bite the bullet and fix. Dont you think the sealent down the radiator might confirm the diagnosis, rather than ripping off the head and finding nothing wrong with it...?
I work from the basis that if i tried to fix everything that needed doing on my cruiser at once, i might as well go out and buy a new one, after all isnt part of the joy of an old car - working on it?
When I find its time to fix something i fix it properlly hence the list of jobs just done on my old girl
https://forum.ih8mud.com/showpost.php?p=1387463&postcount=5
I work as and Agricultural consultant, and i find in all things you have to give people the option of a quick fix to keep things going (so they dont go bust) and a long term strategie so they can stay in buisness and fix the problem
This is why i ask lots of questions on the forum before i make my mind up and act.
Half the fun of this forum is exhanging ideas, we are not all trained mechanics or we wouldnt bother posting
:doh: okay i can accept it, no stop leak :doh:
True the last vehicle i used it on, then got its radiator rodded out and the head machined, was just a stop-gap measure to get the wife to the shops
