Unknown cables...?
GHW
New Zealand
Need some expert help please, I've recently picked up my 60series, 2h with a turbo, a44of trans.
There are two cables that I've have concluded are not connected I can't figure out where each go to, been through the manuals.
The top one, as can be seen in the first photo comes up from the back of the engine and is sitting ontop of the break booster. Can't figure out what it is meant to do or where the other end goes to? The accelerator pedal and throttle cable both are in the correct positions.
The second cable comes from the back of the engine and the cable housing stops above the throttle control on the trans, I pulled the internal wire hoping it would be the other end of the cable on the top but it is not, it pulled out of the housing an extra 150mm or so, I left it there, it was slightly tight to pull but then eased right up. The housing isn't connected to anything I can see, and the cable has a plastic end of sorts that is slightly broken. Photos 2 and 3 show this cable, my hand is closest to the front of the truck and the cable direction is heading backwards.
Neither were connected to anything so any help would be much appreciated. Any ideas???????
Are you talking top or bottom cable?
Its an auto, is the kick down a different cable to the throttle cable?
I was going to say looks like the kickdown cable for the auto transmission as well. Both ends do: One that goes into the transmission and the one with the red cap that is attached at the engine end.
hth's
gb
I thought hand throttle but that has no cable in the engine bay, I don't know, maybe cruise control? heater?
Dont know if this helps, 1985 hj60, manual 5-spd
file.php
file.php
handthrottle is attached to pedal so no extra cable:
file.php
