Unexplained Water Leak?
North Jersey
Just hear me out on this one. I'm getting a good size leak under the dash behind the kick panel trim that soaks the carpet. This leak has only started a few months ago only during very heavy rain. I can only see where it drips below the dash so I don't know how high or where it starts because I have a suspended headliner and didn't want to mess with pulling the cloth trim off of the A pillar. Before everyone assumes the obvious culprits let me list all the repairs I have made. First the windshield has been replaced, I supplied the shop with a OEM gasket that has been completely sealed to the body and to the glass with urethane and cannot be lifted from the body surface in any place and no water pools up on the inside corners of the seal as it did before replacing the seal. Next the sunroof glass is new and I have modified the front drains to drain the water to the outside of the body instead of in the rocker cavity. With this modification https://forum.ih8mud.com/80-series-tech/181371-sunroof-drain-fix.html my drains are 100% unblocked and should stay that way forever because the rocker drain slits area non issue. I have also plugged the bottom of my sunroof drains and filled the pan with water flooding the entire length of the drain. A half hour later the water level had stayed the same eliminating the possibility of the drain tube being cracked or loose from the sunroof pan. I was wondering if it could be leaking from water entering the cowl vent into the heater vents, or any cracked body seal in the area of the leak? I'm at a complete loss any help would be great.
Thanks
George
Nice right up by the way on the sunroof bypass...
Does it leak when you're driving or parked or both? Id take the plastic pieces out and carpet on that side to see better at any given time. I know you say you have done the leak test for the sunroof, but that's where I'd start. If it definatelly leaks when you are parked then break out the hose and start flooding the windshield top and bottom. Also it could be coming in through the vent intake in between the windshield and hood.
Make sure to post follow ups of your findings... Good luck!
Glad you like the sunroof bypass. I have only noticed it when its parked. I tried the hose test this weekend but its so hard to simulate a heavy downpour. I think I'm going to concentrate on the vents because at one time I had water on the bottom of the fan box. Thanx for your input.
