Unexplained thunk.
Wyoming MI
2004 Land Cruiser. 246k.
I recently had the lower ball joints, outer tie rod ends and upper control arms, all sway bar bushings and sway bar end links replaced as well as a alignment.
All four shocks, calipers, rotors, wheel bearings.
Now the steering is really tight and there is a thunk in the front end.
From park into gear, thunk.
Going over bumps, tight turns (u-turns) coming to a stop, shifting into reverse…everything is tight. I cannot find where the noise is coming from anywhere.
I am assuming the tight steering will loosen up with time, but right now when I turn the wheel I have to turn it back, it won’t re-center on it’s own.
I do not know if these things are related or not.
Any ideas?
It’s coming from the center of the front end, so front diff bushing sounds like the most plausible.
Prop shafts were just greased with a PM 1,000 miles ago.
All other work was just done last week.
Any ideas?
if you don't mind me asking, what did you pay for all that work?
