Undercarriage rust
Burbank, CA
Hey Guys,
Getting ready to pull the trigger on an 80, and I am concerned about surface rust on some suspension related parts.
Here is a pic of the front axle from one of the cars im looking at. Its a AZ car, so I would expect the rust to be minimal. Is the surface rust on the control arm seat and some other areas something to worry about ? Will that spread slowly here in Southern Cali.
I plan on keeping the car for a long time and its not going to be a DD. I rememeber my 94 80 didnt have spots like that.
Thanks much,
Harry
Based on your pic, it doesn't look to me like you've got much to worry about. I had issues with some of the bolts on the undercarriage, but not anything a lot of PB Blaster and some heat from the propane torch couldn't take care of. if you're working on a bolt that you *think* might be a little rusty and be of issue, spray it with PB and then hit it with some heat. I haven't had one break since going that route. Just takes a little more patience :)
Dude, I would kill formine to look that nice. You have no worries with rust there. Trucks from the North East that see salted roads in the winter, now THERE is some rust! The one you pictured is as clean as hounds tooth.
That's actually pretty clean. It looks to be minor surface rust, and should go away once you dig in and start working on things under there!
I won't worry about that at all. It is pretty clean actually, wire brush and ZERO RUST should take care of iy=)
