uncomfortable front drivers seat
Raleigh NC
does anybody feel like their seat could use a couple inches of extra travel? im not terribly tall (6'1'') but feel very cramped in my 80. any seat extensions available?
Look for Landtank's brackets in the vendor section.
I found that having the seat rebuilt and reshaped with a bunch of extra softer foam to raise the seating height made far more difference than sliding back. I don't even use the full extension, and I can drive all day in it now.
But do a search, many have reported their pleasure with LT's great design, and it does exactly what he says it does.
I'm 6'2'' and don't feel too cramped but I hear you. Landtank's seat mod should help, although your (occasional?) rear passengers might object to that.
Nay - can you expound on the seat reworking you had done?
The upholstery shop added a lot of softer foam on top of the stock cushion, and then put the leather back on - the seat is flatter now (less side bolster), which I like, and infinitely softer and more supportive. It looks a bit like a sofa cushion now before you sit in it, but I find I still have plenty of lateral support onroad and for rock crawling.
My seat was really dropping out on me and killing my back - I could stand maybe an hour of it. LT's brackets did move the seat back, but I don't like the low rider seating stance in a truck and the seat was still terrible.
I sit up nice and high with a good truck seating position now - probably 1.5-2" higher than the max height adjustment stock. The 80 has a lot of headroom, so you can afford this. I have enough legroom that I don't even use any of the LT extension or all of the stock extension. With four kids and therefore a constant passenger on long trips, this is very important.
My personal opinion is that the 80 design doesn't lack rearward leg room, but the seat is too low and narrow for a taller driver with longer legs. I have long arms - I am still not sure how people are extending two more inches and comfortably reaching the wheel.
Again, I'm not bagging on the brackets, they do exactly what they say they do. It just wasn't what I needed.
The shop work was $200, BTW. I am about to take the rock hard passenger seat in for the same treatment as it kills my wife's backside on long trips.
I may still put in a set of Corbeau Moabs one of these days - the stockers really do suck and when I am in the Cruiser rather than the minivan it usually means an all day trip and often more. The plain jane practically zero adjustment seats in my old 1997 XJ were head and shoulders better than even my modified 80 seat is now, but the 80 is at least tolerable for about 8 hours of highway driving at a time. I can sit it all day offroad now, but I am very sensitive to auto seats, so take what I say with a grain of salt. I really wish my seats where a nice ventilated cloth over leather on top of being wider and higher up, but I wanted to work with what I had for a known outcome, and I'm happy with it now.
Hmmm...I'm not sure how making the seat taller has improved your legroom?? I know for me I ordered the 2" rail kit and I can't wait to get it and install it. I hope that it does me more good than yours did you. I agree that the padding in the seat is not good, and I will probably be doing something with mine as well.
The rail extension is nice. My knee isn't sticking in the shifter anymore. however, I also think the stock seat height is too low, especically in the rear. My back kills me after long trips. I need to find a shop to work on my seat cushion like Nay. Problem is I know it will cost me more than $200 a seat because I want to add seat heaters and new leather at the same time.
I was lucky that the PO had already done the leather on the driver's seat at the same shop - that was about a $400 job I think. I also want the heaters at some point, that will make a world of difference on long trips.
To an extreme illustration, if you could stand up you'd have more legroom :D. What I found was that sitting down low tends to push you forward into the bottom of the seat cushion, which is also what kills your back. Get proper height and cushion support and you are back against the lumbar support with your seatback in a nice upright position. In other words, by sitting higher you sit more back in the seat.
I think an office chair relationship to desk makes a good example. Sit down a bit low to your desk so your knees are up and then adjust backwards to let your knees return to a more normal position. Recline a bit and then try to reach the computer keyboard and have maximum visibility.
Then raise the chair up so your legs are more 90 degrees to your body and sit closer to the desk, keeping your feet in the same position on the floor as the lower more reclined position you did first. What you lose is a bit of the angle to the pedal in order to be in the more upright driving position (pedal angle and placement does favor a more back/reclined driving position).
In a perfect solution I think you need both adjustments to the 80's seats to really get the right position, but again I favor that high and upright position when driving a truck.
I do have to say that if I had to replace the leather as well that I would go aftermarket. These crappy seats are not worth $800 a piece to fix the leather, improve the cushion, modify the seating position, and add a heater element, I don't care how well they match the interior.
Purchased 97 LC in nice condition in March of this year. Love the truck, hate the seats. Being a hair over 6' tall, I thought I needed to buy LandTank's seat extenders because of a constant uncomfortable feeling where I just needed more leg room.
Read this thread.
Put a pillow under my A$$.
Now, all is good.
It's really amazing what an extra inch or two of vertical lift can do to make your legs more comfortable! Where before I used to rest my foot behind the brake pedal (requiring quite some effort to step on the brakes), my foot now comfortably rests by the gas pedal and the brake pedal is within easy reach!
Has anyone else (besides the genius that we know as "Nay") tried this? Does anyone else think we should try to get a custom fab seat height extender made?
If you search, you might be able to find an old post from someone who did this, but it looked pretty dangerous in the sense that the seatbelt latch is bolted to the seat, so you are relying on the seat mount to the floor in an accident, and the mount didn't look reinforced.
I think it could be done, but not sure anybody would produce a bracket due to the potential liability. I think LT has commented that this is one reason he only focused on the slider extension, because technically it is a lot easier to bolt in some mount extensions than to take apart the seat to raise/extend the sliders.
There are different seat in the 80's, some of the cloth/manual seat trucks that I have driven felt like a low rider, couldn't see over the hood. My LX seats work well for me, but my head is close to the head liner, so have no height to give up.
The side bolster gave up on mine, was an easy fix. The biggest pain to modifying the foam is getting it out. If I were to do it, would try different foam types on top of the seat, until I found what worked, then open the seat and cement it to the original foam.
https://forum.ih8mud.com/az-copper-state-cruisers/213566-%9180-series-seat-repair.html
