Ultimate oil undercoating guide (DIY Waxoyl)
NH
Can't forget about you guys... Cross post for the northerners.
Rust kills more of our trucks than any other cause. This ~$100 investment (depending what you own already) can save thousands in body and frame rot and struggling with seized bolts, and keep more of the cars and trucks we love on the road. I've used bar and chain oil for years and a knowledgeable friend has used B&C and Fluid Film and has said they're comparable. Both work OK but need annual reapplication and anything that is exposed to constant road spray like the A arms is bare in a matter of weeks. This treatment will not wash off easily, or maybe ever. For most of the vehicle areas it seems like this will be a lifetime coating. It's a PITA, but worth it.
Ingredients -
2 gallons name brand bar and chain oil ( all season, or 1 gal winter, 1 summer)
16 oz paraffin wax
Spray gun with wands ( I like PMT's - Amazon.com: Undercoating Gun + Spray Wand Kit: Automotive )
Air compressor, 4CFM or higher, 8+ is ideal
Metal paint can
Propane/MAP torch
Scale
Hatchet
Hot plate
Old shirt
Duct tape
Optional:
Infrared thermometer ($17 @ Amazon.com: Etekcity Lasergrip 774 Non-contact Digital Laser Infrared Thermometer -58℉~ 716℉ (-50℃~380℃), Yellow and Black: Kitchen & Dining )
Spray suit (the heavy duty plastic lined one from Home Depot paint section works very well)
Spray sock (for hair, paint section)
Truck/car should be clean and dry underneath.
The ratio of wax to oil makes a big difference. You don't want to go above 2 ounces per quart or the oil will harden at very high temperatures, making spraying difficult, as well as possible chipping at cold temperatures. I put various concentrations on wax paper and put it in the freezer, at 0* anything much above 2oz/qt would separate from the paper rather than bending with it. 2oz/qt begins to harden around 150*. Much below 1 oz/qt would make the mixture more fluid than ideal, this mixture hardens around 100*. I used 2 oz/qt on high splash areas like A arms and low crossmembers, as well as anything I could access easily without a wand. With a wand 2oz concentration tends to harden by the time it reaches the end, but can still work with enough heat.
Wrap spray gun base with an old shirt and duct tape to keep the oil warm, like this:
Put paint can on hotplate, add oil, and turn on high. Oil will begin to lightly smoke around 150* and heavy smoke around 200*, this is too hot for the washer in the spray gun so keep it under 200*. Chip up wax into quicker melting flakes, if you don't have a fine scale weigh a large block and divy it up, then chip it. Add to oil at desired ratio, probably start with 2 oz/qt. When mix hits about 175* and wax is all melted add to gun. Beware the vent hole, don't spill this on yourself! You will have to jump start the top of the gun or wax will harden when it hits this, apply heat from torch to top of gun, from base to tip, both sides, then spray away. The threaded nozzles affect flow rate so play around with that till you find one that works for you.
Anytime you stop spraying long enough for the gun to cool down you will have to reapply heat from the torch to it, especially with the higher wax mix. When using nozzles, especially the long one, you will have to heat them with the torch as well, going quickly and careful not to melt them of course. This is an extra PITA but is an important step to get inside of the frame. Take your time and get inside all holes you can find, in A arms, crossmembers, top of the shocks, etc. I dropped all front skid plates, gas tank skid plate, and spare tire to spray everything. Try not to get anything on the exhaust, especially the catalytic converters. It's a good idea to keep a fire extinguisher in your vehicle at all times, but especially for the first few trips after undercoating.
I applied inside of the doors (salt spray will run down the windows and inside in the winter and rust them from inside) by drilling a 1/2" hole at latch side, spraying with the lower wax mixture, and plugging with these - 100 1/2" Black Plastic Flush Type Hole Plugs 7/8" Head - Hardware Plugs - Amazon.com . I also did inside the rockers.
This is what my GX A arms look like two months after spraying and constantly subjected to NH salt and slush.:
Fully waterproof. You can still see runs on the crossmembers.
3 winter update - Coating is holding up perfectly, zero rust, still runs/droplets visible in areas not right next to the road. Definitely looking like a lifetime coating. Pics from earlier this winter but still looks the same under there, just checked.
Compare to the aftermarket CV I put in at some point after spraying. (Saved the OEM and will replace boots at some point to swap back in when the aftermarket one inevitably fails)
Nice job.
I fluid film the 2001 4runner late fall and a touchup mid winter on a nice day. I used to borrow my sons gun and compressor, set the whole thing up and do the job. Then break everything down, clean the gun and bring it all back to his house.
Now I buy a case of Fluid Film, give some to my other son, then spray about four cans underneath the 4Runner. When I am done I just throw the cans away, pick up the tarp I was laying on and I am done.
It costs more that way but I am paying for my lazyness..
Nice write-up. Pretty much what I have settled on. This year I did try a trick YouTuber Mustie1 turned me on to. Instead of paraffin wax I put a toilet sealing ring into the pot of oil. (I bought a cheap pot and heat up at least a half gallon at a time. Then transfer it to the gun. I probably get it too hot but I've never had to worry about it cooling off in the gun.)
I'm very happy with the results after one winter using the toilet ring wax. As you say in high spray areas there isn't anything that won't wash off. But for floor pans, inside frames and body panels this stuff is gold.
Thanks all. I partially melted a washer that the PMT guns have so was going to cut a new one out of some old EPDM next time I have to spray. Which will hopefully be soon if the heads for my 3.4 swap come back from the machine shop holding compression 2nd time through!
Just to clarify, the last pic shows what the A arms look like after 3 winters and no recoats and it hasn't washed off at all, just the one bare spot you can see on the steering stop (and CV that didn't get sprayed). I used 2oz/qt paraffin on them, and all the low areas.
Bar and chain oil with toilet sealing ring wax.
1931846
03 Tacome original frame 16 years in northern Ohio.
^ Dually Tacoma even! ;)
Not bad, not bad. Mine is an '07 but picked it up in Houston 3ish years ago. Check back in 13...
I've been oiling for about 5-6 years my vehicles. I live in Canada and they see lots of salt.
I've been getting it professionally sprayed the last few years. I use Krown Oil. It stays on quite well. That toilet ring sprayed frame looks pretty good. Is that the cheapest way to buy wax?
I also really like LPS 3. It stays very waxy and you can get it in gallon jugs. Another good spray is rust check. They have a few formulas and the coat and protect is thicker.
That's the first time I've tried it. I don't think it's the cheapest it's just that it's so damn soft and sticky. I've got it on my car too and I've very happy. It's my go to for now I don't see any need to change.
