U Joint Replacement ? "Duralast Gold"
Tropical Fargo, North Dakota
So I have a bad u joint on my rear drive shaft. Need to swap quickly to get truck back on the road to go fishing today.
No OEM part's in town. No time for Cdan.
Call all over town for aftermarket cheapos just to get by for the weekend.
Advance Auto, Checker, OReilly's, Auto Zone, couple of my local part's places that have been good on other vehicles, etc. You get the idea.
Prices anywhere from $60 to $75 per joint. OEM was $70 as everyone probably knows. (Non Cdan, those will be ordered tomorrow).
Long story short I find joints for $16/each at Auto Zone. "Duralast Gold" lifetime warranty, blah, blah.....
I can only imagaine these are crap for this price(and they had ones for $8.99 each too?), but I need my truck today. Plan to put the new ones in, one on each end of the rear shaft, and drive it until OEM's can get here.
Has anyone heard of these things? They even "Never need regreasing". :grinpimp:
What am I missing before I go out in the garage? I really don't want to be in the middle of the lake this afternoon stuck up to my eyeballs in slush, with a broken new u joint and 4 kids and a wife.
Sidenote: I must have actually drove all the way out to the fish house and back(While making that video I posted last week) with this joint going bad. The vibe started on the way to the lake, and I never got out to look under the truck. Man, was that stupid. I'd still be there if I had broken the drive shaft in the middle of the lake. Leason learned. :doh:
All you need to know is "Hecho in China".
I would not bother to install.
Why did the old ones go bad? Toyota U-joints frequently last the life of the vehicle.
I had to do the same on mine a while ago, and haven't got around to getting new ones yet, but they are working fine. In fact, they didn't have the larger cup size in the gold so I had to get the cheaper of the two and am still driving with no problems. You should be fine.
let the joint go dry and its going to be hell-bound on destroying it self, doesn't take long
I went the Gold route because I'm close to an Autozone but not a dealership. 10K miles later and I still have no slop and they're holding up well.
Warning: I'm not a Toyota purist and frequently use non-OEM parts and haven't suffered premature failure.
I suppose that's right, but just a shot of grease every oil change, and they live forever. I remember that back in the day, Jeff Zepp said his were original at 270K miles and as good as new, and I've got some in my FJ60 with 220k also as good as new.
But that's the reason to only install Toyota U-joints. How long is a Chinese U-joint going to last that you can't even lube?
176k and haven't had the loving they should have the past 80k or so. I did grease everything about 5k ago and maybe they didn't like it?
More so probably the the past month of driving on the lake getting stuck and unstuck 100's of times. If I only trashed a u-joint, I'm counting myself lucky :)
YouTube - 80 Series Land Cruiser on Frozen Lake 2
:cheers:
edit: If these joints last even a week, I'm happy because they got me going again for $30.
Yes... I must say I worked at autozone at one time. parts manager.
anyway at that time, like 5 years ago... many of the parts for toyota and a few other rigs were labeled duralast gold or even the lower priced autozone econo brand .. you open the packed no matter where it said it was made... and it says Timken on them. Same goes for many of the autozone so called exclusive brands... you just need to look at the side of the part. At one time their batteries where made by Johnson Controlls. Which I think Nasa uses as well. Also the gold parts are made exactly by autozone specs... no matter what country it is made in....
anyway I have no idea what they are doing these days but it wouldnt hurt to look...
http://www.manufacturers.com.tw/showroom-3634-1-1-0-0.php
http://www.ycbearing.com.tw/
2nd that on the longevity if greased under routine maintenance. The only time i have seen the toyota joints fail was when there was no grease in them from lack of maintenance
Am I missing something here? Didn't the guy just need something to get by on? If thats the case even the non grease type will work. The non-greasable are actually stronger since they don't have a hollow core for the grease to tunnel through. Its not made for longevity but for strength. Dude just put a $9 or $16 u-joint in there for now and get the OEM's when you can.
If anything else you should be able to get 3k miles out of them.
AC,
You don't happen to have the Duralast P/N for the larger cup size joint do you? 1-1612DG is what I have. (EDIT: Duralast P/N for larger 1.260" cup size is 02-0020). I had a suspicion these were smaller cups and sure enough they are. Drive shaft is off and joints out, but now, no parts.
edit: So I call Autozone.
Me: "I bought 2 U-joints yesterday that you showed as being for my rear drive shaft. The cups are too small. Do you have the correct joints in stock with the larger cups?"
Autozone guy: "Computa show dat correct paht numba for dat truck. We have udda size cup, but no have dat one in stock. have to orda it so we gave you udda one instead. "
WTF?
I know WTF. I called Autozone for parts and went with what they said, all the while having suspicions it didn't look right.
Either way the old ones are out and I would've had to wait for new ones anyway. So much for fishing today.
i guess you are:D i was just talking about the toyota joints the auto zone ones should be fine for a while heck i carry one as a trail spare. If you do have one in your axle its not a bad idea to inspect the joint as you should between oil changes I say that because one of my 80's had a u-joint fail and the drive shaft whipped around and took out the muffler and the gas tank, not fun i would not want that to happen to anyone so inspect those joints grease-able or non. sorry for the confusion
-nat
-nat
I didn't quote you and say I was talking directly to you.
VFRMAN,
got your PM before I read the thread and didn't realize you already got boned on the wrong size. If you have any other parts store nearby, like advanced or whoever else, they may have the other size.
Dave
Here's a picture of the broken OEM u-joint for reference. I would assume the one side didn't see much lube in its lifetime? (It's covered in PB Blaster now, not grease thrown all over)
Pounding out the old caps was pretty simple for those that haven't done it. I used a couple big sockets. One just big enough to almost cover the cap to pound down with, and one with a bigger diameter to receive the cap on the bottom side as it comes through.
Now I just have to wait for the new joints to get here.
In the mean time, I think I should be taking the drive shaft apart and cleaning/lubing it up. My head is spinning from all the different posts on the proper way to lube that thing. What's the latest concensus?
1. Mark orientation
2. Separate
3. Clean and let dry
4. Coat the splines
5. Re-assemble
6. 2-3 squirts through the zirk
All with the wheels on the ground?
This whole hydro-locking the shaft thing has me concerned. I may have put too much in at my last greasing. Could that have led to the premature failure of the joint? Or just a coincidence that the joint goes bad shortly after?
Next thought after reading/searching way too much is a possible seized VC. I don't feel any binding, while driving but I need to re-check with a wheel off the ground if the shafts will spin in N/N. On the ground with everything in neutral, CDL not locked, nothing turns. Is that correct? I can't remember the process after all this reading.
It's seen some serious abuse the past month getting stuck/unstuck on the lake that I could see having stressed the dry joint(and everything else). Just curious. Thanks.
Just old grease and PB Blaster.
I have never, nor would I ever, intentionally cause abuse to my vehicle or the parts contained therein.:flipoff2:
Here it is prior to removal. You can see the cap broken.
Ewe! Lucky it wasn't worse.
What's a female sheep have to do with it? Judging by your sig line, there seems to be an animal trend here? :)
edit: ok, wasn't funny. Sorry.
I ended up bringing back the Duralast joints and they couldn't get the right ones soon enough.
Bought a "Precision" joint from O Reilly's for $29 and they had it here overnight. Good service I thought, and it's in and working just fine so far. No more vibrations.
Seems like a decent u joint for the money, complete with grease zerk even :) but the plan is still to swap to OEM's in the future along with taking the shaft apart and digging into this whole "grease without hydrolocking" process.
I'm looking at this as a temporary fix for now, but knowing how I get back to projects, it will probably last forever.
Now, back to fishing.........................
