I just put new OEM U joints in my new driveshafts. They have the "C" clips on the inside. When I pulled my old front driveshaft out, the U joints have the retaining clips on the outside. So, are my old U joints aftermarket? or are there two types?
This is what the old ones look like. I pilfered this off of an ebay listing for an aftermarket joint.
Thanks,
Ed
The new shafts are for a 4 speed. So you may be right. If the U joints on the old shafts were not original, it would be the only thing not original(when I got it, that is)
I take it the u-joints are not interchangable. I have the same situation -sort of- I have a 4 spd tans. 3 spd transfer in a 72' but I have two diff. style u-joints throughout my driveline!
I think there is some confusion here. I have a 3 speed T/TC, but I am swapping in a 4 speed/Orion, so Poser got me a set of 4 speed DS in which I replaced the U-joints, so they are done. When I removed the front (old) DS, I noticed the different style U-joint. I just did not know if there were two styles, and evidently there are.
And, on a double side note.....
If you are looking for the most droop, the mini truck u joint and yolks are the way to go by a long shot. you will need a round flange drilled for the mini truck bolt pattern though.
They use a smaller u joint but it is plenty strong..... Anyone ever heard of someone breaking any toyota u-joint?
PMK
