U-bolts
73lndcrsr
What is the consensus on using a u-bolt slightly larger than the axle diameter?
I have about 3.25" axle housing and the U-bolts I want to use are about 3.5"
I think this will be fine, but wanted get a second or third opinion.
I think you're going to have a bitch of a time getting the threaded ends through the holes in your spring plates.
Just buy the right ones. They're not that expensive.
I should have been more clear.
I have a spring plate that i want to use that will accomdate the u-bolts. I am buying new u-bolts, but did not want to fabricate a new plate.
I may just have to do it and get over it.
Thanks for the replies.
Brad
Brad
Used stock spring plates ought to be plentiful and cheap. I wouldn't let that be the reason to use the wrong part.
If you want to build your own and you haven't purchased the ubolts yet, I'd look into either flipping the ubolts or making high-clearance plates so the nuts don't hang down below the leafs.
Thanks, I am going spring over and do not have my stcok plates any longer. I will just make some that fit.
Ahh. I see. I know it's not a huge difference, but I think you'd want to do anything possible to eliminate chances of movement. Like I said, used ones should be easy to find, or make your own from some thick-wall square tube.
Good luck.
