Tyre and rim sizes
I have a set of Goodridge tyres 255 x 75 x 16 and I'm having difficulty getting reliable information on the type of rims I can use with these. I have the opportunity to buy a complete set of wheels for a really good price with four 225 x 75 x 16 mounted. Can anyone tell me if I can use these rims with my goodridge tyres. I realise that I cannot mix any of the four tyres due to the permanent four wheel drive. But will a rim that fits a 225 also suite a 255 etc. I'm heading for Tunisia in a couple of weeks and I really need to get cracking with finishiong the car.
I would appreciate any help you can give on this.
Thanks a million
Martin
The forum's crystal ball is currently undergoing some renovations-:D can you tell us what size the wheels are? Tire manufacturers publish "approved" wheel width ranges for any given tire size. I would think that anything approved for a 225 will be the same for a 255. Bottom line is that as long as the tire manufacturer is OK with it, you can pretty much get away with anything 7"-10" on an 80-series. My guess is those two sizes will both fall into the 6.5"-8" category.
The other consideration is backspacing... to measure, lay the wheel down on the ground with the "pretty" side facing down. Lay a straight edge across the rim and measure up from the mounting flange (where the lugnuts go through) to your straight edge. You'll need it to be pretty close to what you already have- typically 4.5" will put you in there.
