I woke up, did errands and crap, filled up my tank and got my truck washed.
Parked it for about an hour, and when I came out and started it again, it was idling rough, like I had just pulled the EFI fuse to turn off the CEL. Except I didn't do that. And the CEL was on like it normally is because I can't cure the stupid code 71.
Any idea what could cause this?
And also, the truck came stock with lockers. I was wondering what the hose that goes out of the top of the front axle, on the left side, almost directly below the oil filter is. I tried to get a picture but there's stuff in the way. It's a pretty small diameter hose, and it's got kind of a triangle-ish metal thing on the axle.
Because the hose is covered in quite a bit of sulfur smelling oil. So I don't know if it's a breathing hose or what, but should it be saturated in diff oil? I recently filled my diffs up with the recommended viscosity gear oil.
I'd like to know possible reasons for it leaking and what exactly it is. It might be fixable by just replacing the hose, but I want to get a second opinion.
