Two restoration questions
Denver Colorado
Nearing the final phase on my frame off and I have two questions currently, hope you guys can help.
First is I stripped what looked to be a perfect 40 hood down and found a mystery. Under the multiple layers of paint, and primer I have tones of what looks to be 24 to 30 grit sanding marks. What should I do to get these out and get the hood smooth again?
Second, a while back someone mentioned a replacement chemical by 3M I think that you could use on the body seams. Anyone know what it is? I can't find it doing a search. This fills the seems between the quarters, and the seams around the cowl up front.
Thanks in advance!
Flexi-clear body seam sealer...
Paintable, remains flexable after paint, works great.
Are these 'sanding marks' in the bare metal?
Use a 240 DA(dual action sander) on those marks and see what happens...
Othewise, sand them the best you can, and use some spot putty or a little mud and call it good.
Good luck!
-Steve
Good luck!
-Steve
First, thanks to both you guys. I'll pick up the Flexi Clear from the sounds of it.
Seocnd, the sanding marks are in the metal itself. I was using my DA with 100 garnet and I was not even making a dent in it! I'll try the 220 suggestion, I think I have some left from a previous project.
One word of caution about filling body seams, if you tear up a panel, you'll have to repaint the whole tub if you want it to look right. Maybe there is a way to touch up an area without using a break line to mask off but I'm not good enough to do it.
Have fun.
Zac
3m 8505 "fast and firm" sealer is the closest to the oem sealer that is layed in beads throughout the tub.
its tricky to get the motion down to fill the seams smoothly, but I found that running a thin bead in first, and smoothing it out to actually seal the seam works well. let this dry(for a day or so) and then you can run a second bead for the cosmetic purposes of matching the appearance of the oem seam sealer bead. the 8505 3M stuff shrinks a bit, so let the first bead dry.
For the deep scratches, I'd put 180 on the DA, give it a good go and then use the high build primer. I'd stay away from spot puddy (they all shrink over time). Once you lay down 3 coats of high build block it down by hand with 180. Give it 2 more coats of high build, the DA with 240 and you should be good to go.
The new high build tinted epoxy primers really kick ass. I used the napa crossfire tintprime when I redid my 40 last year. The stuff can be laid on so thick it's almost like spraying body filler. It made my not so great bodywork look very presentable. The stuff was expensive, but way easier for things like sanding marks than using spot putty or body filler and lots of sanding. The primer sands out real nice by hand.
Wow, thanks that sounds like what I need. I'm not to worried about the cost at this point, I am so far into it anyway.
