Alright,
Here is the final decision, mostly inspired from a relook at Kurt's trailer and Wildyotes trailer...
A single 2.5" structural square tube with .25" wall. This will eliminate a bunch of fab work and geometry at the front end. It will also be the easiest to get really really square. There won't be more than 120lbs on the tongue at its HEAVIEST, so all the extra steel just isn't needed.
This also allows me to use a ball coupler on road, and then unpin and install a lunette ring for light trail work. I have a ball/pintle combo. In addition, the ability to do a 90 degree jackknife is possible with this setup.
The drawbar will be fully welded through the front and second crossmembers.
I will "gusset" the draw arm with 2" HREW tubing with .125" wall bent up on a bender, and the basket will sit on top of it. Clear is mud? The draw bar will be welded at each intersection of the crossmembers.
Any opinions? Flame away
Drew
The rough dimensions are 4x6'
2x3" tubing with .125" wall.
I thought about running the tube down the length of the trailer but I am hiding my water tank under the box, above the axle and right where the receiver tube would run...
What do you think?
Rezarf <><
Frazer,
Your idea with the spacing on the pintle is ok. Use the 1/4 walled tubing. Extra long bolts and your good to go.
Your towing a small trailer, it's not much load. The bolts are in the same load as if they were shorter. The bolts are in 100% tension load. Not shear. So the length is not important. It is all tight and solid it will be ok.
Use bolts designed for tension loads. Pick expensive high grade bolts. Use lock washer and same grade nuts. Do not use fiber or vinyl lock nuts, it lowers the grade to 5. Not good for tension loads(shear OK).
If you were towing a 20K trailer around on a pintle I would say use a solid spacer. But the 1/4 wall tubing spacer will offer plenty of strength. You could even cover the ends(boxed) for further strength.
Thanks BrownBear, I scored a 4x4" structural tube with 3/8" wall... it is beefy!
I may bolt through the crossmember and the pintle seperatly instead of one long bolt, is there anything wrong with that?
Rezarf <><
Look in the trialer section. One of the guy sthere did a CAD section 3D drawing of the hitch I described. Shows it better than any photo could...
Mike
I thought this was the trailer section? Being in a confused state is normal for me. But do you have to help me stay in it? Seriously, is there another trailer section on IH8MUD?
Sorry, CS, this was in a trailer discussion on Expedition Portal, one that Drew has also been participating in...
M
Thanks for the clarification! I need to do a little more searching around on Mud I think. Probably a lot I am missing out on.
