In my text when I refer to the back of the basket I mean, when mounted, that part of the basket closest to the tailgate.
When I first observed the distortion of the basket after arriving home, the first thought I had was the fasteners must have come loose. But they were all as tight as they should have been. You can see in the photo when the basket was mounted that the back is parallel to the ladder rung, so no slipage had occured there. By the way, I think that photo makes the gusset look out of allignment because the default setting of my iPhone is "LIVE" which may have distorted the appearance of that bottom fastener.
While it was mounted, I placed the high-lift jack so as to raise the two front basket corners. The driver's side had drooped substantially more than the passenger side. I think the comment from Iceman suggested the difference was because of the two identical gussets and if I had received left and right side gussets the distortion might have been even or maybe there would have been none.
In the two photos below, the first is taken from above while the basket sits on its back. The silver item is a metal straight edge and is resting against the bottom of the basket at the back side. Here you can see a slight bow of the bottom. The bow is not more than 1/8", but it may have been more before I straightened it.
The second photo is taken from above and you can see there is only one mounting option, where the gussets are fastened 7" apart, the same as the holes in the ladder. So the basket and its cargo have to be evenly centered.
The straight edge shows a remaining slight bow at the top of the basket back side. This is where I used woodworking clamps to squeeze the center of the back so it is more straight. I used square tubing on the front side so as not to distort it and it remains very straight. Before the squeeze, the bow of the back was probably 1/2" or more out of alignment. This is where the basket gave to allow the droop. It remained flat against the ladder where it was fastened tightly, and the corners of the back were pulled away from the ladder. The sides remained straight and were pulled down pulling the back away from the ladder and pushing the bottom of the basket down.
There is no sign that the bottom was distorted which surprises me, and the joints of all four corners look perfect. All the other edges and surfaces are very straight. Using a carpenter's square, I determined all the corners are square.
