turning radius and pitman arm/ TRE
Question for those of you with Saginaw ps. Ever since I went to 1-ton TRE's the TRE hits the spring when turning full-left. I am running a 7" flat pitman arm with a bottom taper, so the TRE is underneath the pitman arm. I am SOA with shackle reverssal and my springs are pretty darn flat. I used to be okay before when I was running the rockfinder shackle reverssal. But cut that crap off when I did the SOA.. Also, the brackets for my PS box is a Butch Lewis kit, and has the box sitting flat, instead of tilting up which may allow more clearance for the pitman arm than I am getting.
I am exploring options for getting the TRE out over the spring, but wondering if most people allow their TRE over the spring at all. If youre pretty twisted up and the spring touches the pitman arm- alot of force will be put on it. However, I can eek out another few degrees of turning radius if the TRE didnt hit the spring..
Anyone..?
thanks!
Dustin
I have the same setup as you. I just went out and turned hard left and my pitman arm stops 1/4" short of the springs. I just rub a little with full left turn and driver tire stuffed.
I have two thoughts. First, you could go to a 2" drop pitman arm and tapper from the top. That might just get you out over the spring.
Second, is do you really want to get out over that spring. At full stuff something could break. Also the extra few degrees might be the end of a birf.
aw
I had a similar problem with a SUA. My solution was to take the pitman arm off and file the big index teeth in two so that I could make finite adjustments vs 1/4 turn adjustments. I then turned all the way left and installed the pitman arm so that it would not hit. Just make sure when you swing it back right the arm does not get past a parallel position with your bumper as this could cause a bind.
Also you will almost always have more steering one way vs the other given the geometry of the tie rod and drag link/pitman arm unless they are completely parallel to each other in the left to right plane.
ALF
hmm, reindexing the arm is an interresting idea, though I dont feel comfortable doing it with big tires.
Offrd63- is it the tie rod that is 1/4" from the spring or the pitman arm? I wish I had another rig to look at.
I am wondering if I am allowing the rig to turn too sharply right now, but its not sharp enough with the tre hitting the spring.
thanks!
Dustin
I wouldn't worry about the big tire issue as I am running 37's. I messed with mine for hours before finding out the only solution was to 86 the indexing.
kls
On my rig it's the 1 ton TRE that is 1/4" from my reversed spring. I am useing 4x4 Labs high steer.
People have reindexed the pitman arm. I seems you could acomplish the same thing by shortening the drag link. I don't know if either of these methods will effect the self centering though.
So if you remove the pitman arm, just how much more left turn do you get?
aw
hmm. good point about shortening the tie rod. :idea: Need to put it on the chop saw to do it since I am practically bottomed out on it (tre's are about as close together as I can get them. I will look into that tonight. Man, such a simple fix I didnt think of it :beer: :beer:
thanks!
Dustin
