turn signals
Holladay,Utah
I am having some problems with my turn signals.I have everything working except for the drivers turn signals.Hazards,brake,reverse and the pass. turn signals all work great.The drivers turn signals come on but wont blink.I have taken them apart and sanded areas for a good connections.I suppose that there is a bad ground somewhere.All the turn and hazards went out momentarily but mysteriously started working again and its a good thing because i almost put a match in the tank and called it good.Any suggestions would be much appreciated.
I had this same issue and it ended up being a dirty contact in the turn signal assembly in the steering wheel. Have you checked that yet?
turn signal
No,but I will check ,and clean those parts and add some grease to the connections tonight.Thanks for the advise.I hope thats it.
I had a very similar problem. I fixed it:)
as you said before, a bad ground could be your huckleberry. other then that and the turn signal switch, it could also be your hazard switch. good luck
fixed
Well after going through and cleaning up all grounds,housings,flasher,hazard switch,turn switch and fuse block,my L turn still didnt work.It turned out to be a bad bulb,that looked to be good.All my s*** is finally working.Went to install glass into tailgate and finish it all up.No power to the tailgate,that I had running 2 days ago.Long story short,had to add a ground to my new junction strip.Everything is very clean and good for now.Thanks for all the tips:)
when are you gonna start driving el piggy?
