I am in need of some help. My 79 FJ40 has been running great now for about a year(knock on wood
), but have run into my first big problem. When I hit the turn signals, either way, it just stays lit and does not flash. When I pull the Hazard knob, however, they flash. Also, ocasionaly when I push the clutch in and the turn signal is on, they flash once, and then once when I let out. I removed my steering wheel and inspected my coloum switch and everything is fine and as far as I can tell, all the wires running to the flasher box look ok. I was going to remove the box, but cant figure out how to get any tools up in the dash to unscrew it and remove it. If you know how to remove this box or of something else that might be cuasing this, please let me know.
Andrew
), but have run into my first big problem. When I hit the turn signals, either way, it just stays lit and does not flash. When I pull the Hazard knob, however, they flash. Also, ocasionaly when I push the clutch in and the turn signal is on, they flash once, and then once when I let out. I removed my steering wheel and inspected my coloum switch and everything is fine and as far as I can tell, all the wires running to the flasher box look ok. I was going to remove the box, but cant figure out how to get any tools up in the dash to unscrew it and remove it. If you know how to remove this box or of something else that might be cuasing this, please let me know.Andrew
