Turn Signal Relay Question 71 FJ55
Jackson, WY
I tracked down my turn signal issue to the relay pictured below but can't find the exact one I have anywhere nor what appears to be the listed part# for a 71.
The part number on my actual relay is 81980-22010 with googled picture below.
When I look up turn signal relay in parts sources it lists 81980-31030 for my 71.
Heck, I'll take whatever I can find that works but can't find either of the above. Anyone have a lead on the above or if not, what other relay #'s could work?
Try carefully prying apart the relay that you have. Sometimes the points get corrosion that can be sanded off with emory paper. Or a wire may be broken and can be repaired by soldering. If one of the coils is smoked then that's another story.
