Turn Signal / Regulator issue.
I have this weird thing going on with my indicators (aka turn signals). The fuse keeps blowing while driving but works fine with the engine idling or not running. The ammeter sits on 30+ amps with the engine running. If i pull the indicator fuse the ammeter returns to zero. The fuse makes a healthy arc when removed from it's holder even though the indicators are not going. The indicators work fine while the fuse is good.
I checked out the wiring diagram (74 FJ40) and the indicators seem to be wired into the alternator/regulator. I diconnected the regulator and the ammeter dropped back to just below zero. I also noticed that when I pulled the indicator fuse the engine rpm increased. When I put the fuse back in the rpm dropped back again. It seemed like the alternator was loading up when the fuse was in!
I am guessing it could be the regulator? Anyone else have any suggestions?
Thanks
Ben
Try replacing the flasher........
