Yes I searched, but unlike the posts I found, I do not have hazards and all that extra "modern" stuff on the 63 FJ FST. Okey Dokey.....
My signals stopped working yesterday as I was driving about. The 5A fuze was blown. And before or after this the flasher just clicked once and no indication on the dash where perviously there was. After fiddling, not really doing anything but figuring out which fuze was which, the flasher just buzzes at 60Hz more or less.
Could this just be a blow bulb in the turn signal or do I need to do more digging?
Your guidance and help is appreciated.
Bill
PS: Does the flasher ground through its case and the bracket that holds it which is bolted to the firewall?
Bill
They also sand blasted the fuze panel with the fuzes in. That may have loosened up the riveted construction of it. So after checking voltage along the lighting circuit I noticed that it wasn't making it across the fuze. I squashed the little clamps tog ether some and voila.
