After reading thru some of the turn signal post, I was wondering if only changing the instrument cluster indicator lights to L.E.D.'s can effect the flasher unit. Would only the indicator lights have an effect on the heat required to open and close the flasher? I know have turn signal that randomly function. I also changed out the headlight switch light and was wondering if I could have loosened the flasher plug. Are the no load flashers that are mentioned a plug in or are there any wire harness mods required?
Thanks Dave
Thanks Dave
