Turbo oil outlet pipe block bolts stripped, seeking fix options
Caboolture, Brisbane, Qld, Australia
Heya Mudders, Turbo oil outlet pipe bolts at block stripped, seeking fix options & reasons occured please
The bolt and pipe flange you show is for the oil return, not the oil outlet. Try running a tap down them (M8x1.25) and seeing if new bolts will take torque. It's only 13 Nm for those bolts. Threads strip due to over-tightening, a perennial pastime of poor mechanics. If the tap does not work, you'll need to drill, tap and put a thread insert (aka Helicoil) in. Not difficult in itself, but you may have access issues.
