Turbo 400 Question
El Dorado County CA
On level ground travelling 30-40 MPH when I know my trans should be in third gear my trans will up downshift and upshift several times until I either let off or add to the gas. Anyone have any ideas?
There is no mechanical throttle position switch on my carb, There is an electric positioner on the gas pedal. I have unhooked it with no change and metered its resistance OK.
I have not replaced the vaccum modulator but am inclined to do so. (Only cause that is all I am willing to work on)
Thanks,
JB
water and 400
Your probably on the right track. One heads up though, turbo 400 filters will tolerate very little water before it stops them up. Its a very close spun fiber. Have had to poke a whole in them to make it home. Been in the water lately?
On the left side of trans there is a vacuum pod with a adjustmemt screw in side the hole the hose gos on. You adjust your shift points there.
