Tundra on a Texas Ranch for 100K miles
I have a test for that truck.
I work at a surface coal mine. You should see the use and abuse our fleet gets. That truck looked way too clean. Mud and winter will tear a vehicle apart. Sure they had rough roads to drive over, but that truck looked like it never got in any real mud or other adverse weather, those are variables that would have changed the outcome of that vehicle. I also can't believe the tailgate was in such good shape. I've never seen a ranch truck that didn't have a big ding in the top cause they backed into the goose neck, or they had to fix something and used the tailgate as a work table and beat a wheel bearing out of a spindle or something in the field. I also didn't see a mountain pass for hundreds of miles around that place. Take that stock trailer over Eisenhower Pass and see how she feels then. My 40 has towed alot too on flat ground.
To compare, we use Fords here, have for 35 years. We have tried Dodge and Chevy. The Dodges did poorly in all aspects. The Chevys have weak front ends, really bad clearance and if you even once touch dry ground in 4WD, they will grenade the transfer case. We still have two Chevy crew cabs, they have both been through multiple transfer cases in only a 4-5 year period. The Fords seem to be doing the best right now, but by no means are they great, but I still think they have the best chassis of the big three.
I have a 2001 F250 that is mine to use here. I started driving it as a summer employee for two summers when it was brand new. I then returned here and I still drive it. The truck has 43,000 miles on it. It does not get used on a daily basis except in the summer. Winter time I use it about 8 hours a week. This truck sees severs duty conditions. Lots of cross country driving through reclamation, rills gulches, contour ditiches, cab high grass, shrubs, and hidden rocks. In the winter it is not uncommon to push snow with the bumpers and fight mud as deep as the rims. The truck is usually coated in heavy Mag Chloride laden mud.
Early on the front flaps and such under the radiator tore off, skid plate underneath is a pretzel. Within weeks the steering stabilizer that was mounted on the bottom of the axle was toast. We lost all the radiators a few summers ago by hitting a large rock that went under the front bumper and hit the radiators cause they hang below the front frame. Fuel pump has failed, tranny was low on fluid from the factory. Brakes only last about 5000 miles here, all U-joints up front have been replaced several times. Front driveshaft was a failure from the beginning, we use custom shafts in these trucks up front now. Rear drive shaft pucked a U-joint last summer. I also had a broken rear spring, half the helper leaves were gone, only the main and overload were left.
Tranny shifter is loose and junky. It freezes in the winter with mud around it and can't be shifted. Park brakes are a nightmare for the same reason. It is extended cab with the third doors, they rattle to no end, you can see light all around them. Paint is peeling off the rockers, and the top of the hood. Rear door latches don't work very well, door hinges are worn and heater blower has been acting up. Don't get too much water inside, it shorts out the fuse panel, and this just from rinsing the floor off or lots of snow and mud. Too much moisture under the hood also shorts stuff out. Alternator died last year. And the thing is burning a quart or two between services, blues blue smoke on startup. We service every 3-4 months, and you can tell by the miles and age, it does not go 3000 miles between changes.
Yes my work truck is somewhat abused, but at the same time I do try to take care of it. Alot of the failures on it and the overall wear is just ****py parts in an extreme environment. I don't think a Tundra would take any of the abuses of the mine site any better, I think it would fair worse. The mud and cap eats up all the rubber components in the suspension for one, along with u-joints.
I would like to test a Tundra here though, give it to us for 100K and see what it looks like, but we are not average users, so they shy away.
I cannot begin to enumerate the faults of the truck you drive. Let's see, of the three deisel engines available for sale in a pickup, the Ford is, oh yeah, the worst. And the transmission is of the three choices... oh yeah, the worst. Hub bearings? The worst out of three pathetic choices. Railroad ties would give as much comfort as the front leaf springs do. There are some hideous shortcomings in the Dodges as well (not the 5.9L Cummins though) like blend doors that break if you move them with the fan on high (and the moronic engineers never bother to change the design) hub bearings with plastic cages (my favorite) weak front control arms that die prematurely. Chevrolets are basically El Caminos. No clearance, doors that fall off, about as much suspension movement as a golf cart. Saying the Tundra is better than any other half ton is not saying much since our fabulous domestic manufacturers has set the bar so, so low.
FTR, saying the Chevy's transfer case is weaker than that of your Ford is a pretty good laugh; they are the same.
Seems to me they left out one test element..... moisture. The dusty Texas ranch probably is very dry all year. Throw 5 months of snow and cold in too. Personally I think the results would be as good, but they left out a significant element most of usdeal with.
Being in New England, my Tundra sees severe service in all conditions. 37" tires, heavy front bumper with winch, and a 600 pound plow during our snow season.... Heavy towing, off road, it'salso supercharged and the go pedal frequently meets the floor. I beat it like a Toyota Land Cruiser or Truck is meant to be. Granted, it's only has mid 20's for mileage, but everything is tight and functioning well.
In that particular instance they did.
Maybe for some reason. I went through 4 bumpers in 3 years. Could not figure out why they kept getting bumpers from the same source. I have not chromed ones now. If they rust out and they refuse to do anything about them I'll go to something else.
More true than any of us diesel-seekers care to admit.
Didn't NUMMI close because Give us Money backed out on the partnership for it?
I hate that Toyota lost the Matrix through that, that was a great little car. If I could, I'd DD one.
Please do!
You can still get a Matrix. They're made at the plant in Canadia with the Corollas.
Maybe for some reason. I went through 4 bumpers in 3 years. Could not figure out why they kept getting bumpers from the same source. I have not chromed ones now. I they rust out and they refuse to do anything about them I'll go to something else.
Are these factory bumpers you're having problems with or aftermarket copies?
Factory. They warrantied the first two no problem. The third one they were about to do, and even pointed out the front bumper was starting to rust around the fog lamp holes as they are prone to do. When the service writer found out the rear had already been replaced she started trying to find reasons to not fix it.
I called Toyota USA when I got home. The stealership called me within the hour to schedule replacements for both bumpers.
It was a big reason I bought a 1st gen when I turned in that one on the lease. Having a crappy part is one thing. Especially on a brand new truck with tons of domestic parts. Not fixing a known problem is a much bigger problem. Not standing behind a your problems and making them right is not one of the American style attributes I expected Toyota to include on their American style truck.
The baby Tundra wasn't big enough, so I traded it on a 2ng gen, but one without chrome bumpers.
I gotcha. I was going to recommend that you contact Toyota directly if the dealer won't offer any help. 800-331-4331 if you ever need the number.
This thread has been very interesting :)
I will now refer to all chebby trucks as El Caminos :D
