I know that bjowett and a few others have converted to Tundra A arms and brakes. The actual details of the conversions seem to be scattered over several long threads. I would suggest making a sticky post with the condensed conversion details (I.e. PNs needed, DIY tips, and wheel selection tips). I'll try to filter and paste relevant info into this thread, but I would really hope the people that have actually done it would chime in.
Does the longer arm and greater leverage change spring and shock performance much? (Enough to warrant a different spring and shock selection?)
For the same lift, how much travel is gained over the 200?
Those that have done it, would you do it again? What would you do different?
What offset works best for 17" wheels and Tundra arms?
I figure if collecting the parts for the conversion, it is good to know what aftermarket upgrades are available. What parts are okay to source used and which should be purchased new?
Several companies make high travel UCAs for stock width Tundras, does anyone make high travel lowers in stock width? Are used Tundra lower A arms okay (assuming not damaged)? Are 200 and Tundra spindles the same or different? Is there a brake kit that works better than stock Tundra and still fits in 17" wheels?
