Tube Bender
[quote author=Junk link=board=1;threadid=4950;start=msg38802#msg38802 date=1062988349]
Cruiserhead, where you at in North Jersey? I'm near Morristown.
[/quote]
Junk,I`m in Butler just off of Rt. 23 North. :D
A tip when using one of the Harbor freight pipe benders on tubing. To take up the space in the die (tubing is smaller than pipe) use an old tire tread that is as long as the die.. The hydraulic jack will compress the tread around the pipe to make a tight fit. If you fill the tube with sand and add a little heat the interior bend will not crimp as much.
