Tub Swap
Discussion in '40- & 55-Series Tech' started by amos715, Mar 2, 2007.
  1. amos715
    amos715
    580
    Media:
    7
    Albums:
    1
    1
    Nov 8, 2006
    6 Miles Past The Edge Of The World
    OK one more question........ OK probably more than one
    My current cowling is in really good shape so when i swap my tub i will probably cut it off at the rocker panels? yes that's a question
    would a tub swap be easier to just remove the cowling from the newer tub first, and just swap out from the floor pans back?
    and if so what is the best way to keep from damaging the cowling and rocker panels, should i just cut the weld with a grinder?
  2. spotcruiser
    spotcruiser Geezer SILVER Star
    3,380
    563
    Jan 30, 2003
    Western WA
    I swapped the rear tub of a '78 with the rusted out part of my '76. Worked great. I grafted them at the seam behind/below the "A" pillar. You want to cut on the waste-side of each piece and then clean up to the part that you want to re-use. You can drill out spotwelds and then use the holes to reattach the parts you put back together. The floors are just spot welded at the A-piller, so just find the spot welds and drill them out
  3. Toyo FJ40
    Toyo FJ40
    1,020
    Media:
    8
    Albums:
    1
    Dec 7, 2004
    Eastern PA.
    I cut my cowl off at the door jam and across the floor just behind the front tub body mount, There is a couple of spot welds and a weld at the top of the rocker panel. Theres one bolt on each side which makes it nice to reassemble. You can bolt it together and get it lined up before you weld it. I cut it with a cutting wheel in a angle grinder about 2 inches more than I wanted and trimed it back to the body seam at the door post. I let the floor over lap about a half an inch and welded it back together. Just make sure your door openings are square before you weld it.
    Kevin
  4. F-junker
    F-junker
    1,774
    3
    Oct 25, 2005
    Hagerstown MD
    I wish my PO checked for squareness on my drivers door jam... F%$^& Butthole!!! Oh well, I've been eyeing up on of those pretty all aluminum babies! Now all I need is another 8000 bucks and a matkins frame!
  5. amos715
    amos715
    580
    Media:
    7
    Albums:
    1
    1
    Nov 8, 2006
    i have tried to call the Matkins frame people like 10 times and i never get anybody.
    any ideas?
    And thanks on the tub questions, i will mostly be doing this by myself, so i am trying to find out the easiest route.
