tub removal
southampton ny
I am planing to take off the tub from my 78 fj40. Can it be removed independent of the the cowl? If so any pointers would be greatly appreciated.
Thanks
Are you planning on reusing the tub(from the cowl back)or are you scrapping it? Seperating the tub from the cowl wouldn't be a great idea if you plan on reusing it; it's possible, but it would be a real bitch to unstitch all the spot welds and seperate the tub from the cowl without any damage. If you're going with a new 3/4 tub then removing the old tub is pretty easy, a sawsall, a spot weld cutter(or plain old drill bits work) and maybe a grinder and your set.
Removing the tub from the frame is really not that hard. But, you'll have to disconnect wiring, brake lines, heater hoses, steering column, accelerator linkage, ebrake, speedo cable, choke cable, and that kind of stuff. Have a new set of body mounts on hand, because you will probably break or have to cut some of the old mounting bolts during removal. You want to replace the old worn mounts anyway. The tub is one piece from the cowl louvers to the tailgate. As noted before, the rear 1/2 tub is spot welded to the dash/cowl. Don't separate them unless you are replacing some or all of one part or the other. Two guys can lift the empty tub off of the frame, but three or more people makes it easier. You can store the tub on it's side or on the tailgate to save space while it is removed.
Good Luck,
Todd Bull.
Not to hijack the thread but, how high can you lift the tub just by removing mounting bolts and cables? I'm thinking about por15 on the frame and dont wanna take it all apart if I dont have to. just a quick ?
Assuming you are going to work / store your tub on a hard surface (concrete or black top) plan to make your self some type of dolly on casters. It makes moving it around very easy. Still will have to have several folks available if you want to flip it upside down to work on underside. I just made one out of 2x4's and plywood. Works great.
The tub is just bolted to the frame at six or eight places. That part's easy. To remove the body from the frame completely, though, you need to disconnect the wiring, hoses, brake lines, and such that run between the tub and the frame. Of course, you'd want to remove the rollbar and seats (don't have to, but makes it much lighter and easier to handle).
If you just wanted to lift the tub off the frame a few inches to paint the frame and replace body mounts, you can do that by removing the mounting bolts and jacking/blocking the tub up. You may have to disconnect the steering column and maybe open some wire hangers. If you really want to do a good job of cleaning/painting the frame, though, having the tub off entirely sure does make the job easier.
It's all just a matter of how thorough you want to be.
