Tub interchangeability
Long Island
Hi Guys-
Is a 75 tub exactly the same as a tub from a 12/73 build. Is the cowl, door, hinges all the same? Also what year did the metal quality of the tubs go downhill?
Exactly the same - no. Will they interchange - yes. What's different, but will fit:
  • Doors (except rear ambi doors)
  • Door hinges on the tub will work
  • Different windshield frame and hinges
  • Different dash knob and switches
  • Different transmission cover and shifter hole
  • Door strike plates
  • Gas filler and door (or lack thereof)
  • Throttle linkage and pedal mounting are different
  • I believe the parking brake routing is different
  • Others can chime in for the rest.
  • Steering column mounting is different where the column passes through the cowl.
  • '75 has a cover over the gas tank.
  • Hinge location for the early barn doors don't match locations for ambi doors.
  • '75 has mounting locations for OEM roll bar in fender wells, don't recall if '73 does.
