truxxx lift?
If it is just for the look of a lift you should be ok. If you want it for wheeling you would be better off with a spring shock combo like OME or some of the other suspension kits.
never heard of it but it looks fine. The fronts are clever, you just bolt to the top so you don't have to disassemble the coilovers.
Only question is quality but spacers arent rocket science. If you get it, post some pics :cheers:
Although tempting.... dont do it.
It brings EVERYTHING down, including the point at which the suspention down travel bottoms out, meaning you will be over-extending your CV joints, boots, ball joints, ect the first time you go off roading and hang a front wheel.
(especially cranking the steering while hanging a front, you will pop a CV joint out of its socket from such extreme over-extending)
