Here's a LIST:
(Mike & Junk both hit a really important issue, each!
1-Get that other half shroud & install.(Junk)
2-I'd resist 1st instinct to replace fan clutch(Junk & Me, fyi, it shouldn't stop turning <1second when shut off when HOT....that's not right, should be 2-3 seconds, but if still locked up Your clutch is fine, move to the next possibility)
3-Drain (& Save) coolant. If it looks good, You can strain it thru coffee filters poked in a big funnel from catch basin back in to jugs.
3-Get a couple bottles of radiator (& Block) flush, add w/water, run them thru whole system while keeping enough fresh water flowing thru block & radiator drain to maintain full level; Or
4-BOIL OUT radiator (either above radiator flush or take to radiator shop & have them boil out & pressure test), while they're at it they always wind up cleaning exterior fins, which is best done if that was Your only issue, w/a can of "Air Conditioner Condenser Unit Cleaner" which can be had at any major hardware chain, spray it all over, follow directions & wash it off GENTLY (I've seen folks take spray nozzles so powerful they dissolve fins, & Yours looked Pretty Dirty from back side? [If they're dirty on back side, no air is making it thru from Front side? Using it on A/C Condenser & Transmission cooler is a real good idea (ok, so, get 2 cans of that stuff & use 1 just on Trans Cooler & A/C Condenser; other on the back side of that radiator's fins, multiple cleanings. Incoming cooling air has to get past Both A/C Condenser & Trans Cooler to get To Your Radiator. See where Your temp holds after all the cleaning.
5-Did You check/change/possibly damage Block Coolant Temp Sensor? Wouldn't it be ironic if all Your 'paranoia' was caused by a faulty sensor?(Mike's idea)
6-Just because You can, I'd change Water Pump. Yes, we all read it was new 54k mi. ago, & well, every now and then we all get a 'lemon', You might have too.
Warping Heads &/or blowing a head gasket, over a super heated block is a much more expensive fix than that new water pump?
Multiple other 'guru's mentioned what You said is that when at a stop & idle, temp is spiking...that can partially be due to missing shroud section but I'll bet a dollar it's Water pump/serpentine belt, seen it 2 many times. Lower rpms has it not moving enough coolant. Yes, Austin IS Hot as Hades this time of Year, but there are a few legit reasons You've got these issues; most aren't pricey fixes. It can Easily be several issues combining (along w/100+F ambient temps) Did You test Water Pump Bearing? (Grab fan & see if there's even Slightest wobble/movement fore & aft at fan blade tips....anything more than blade flex...yes, kicking on Heat moves more coolant, but that doesn't confirm Your pump is at 100% & IF bearing is going. slightest movement out at ends of blades will show the 'wobble'.
Any 'squealing' or belt noises? These are usually telltale for either water pump/belt or fan clutch issues. Both water pump & Fan clutch should be targets AFTER all that cleaning (Especially since OEM Thermostat was just replaced).
1 thing for certain....Your Replacing Starter, intake manifold & injectors had Nothing to do with this. Obviously neither did heater inlet/outlet hoses.
1 good thing....You didn't mention loss of coolant? (IF You were losing any, there'd be "caked up PINK Dried "foam" at every leak point, whether clamp, hose, fitting or housing.
Here's a final (potentially scary) possibility referencing head gaskets.....How's Your OIL Look on dip stick? (if it were mine, I'd go look at the stick RIGHT NOW, if it's creamy looking like coffee, at least 1 of Your head gaskets already blew & that's Your cause for overheating(But this always includes loss of coolant)? Generally this has a dead giveaway of massive amounts of steam at exhaust, it's hard to miss, but not always....the dipstick never lies. Temps at 240 if they happened or happen again, can lead to this failure, so screw the a/c, no matter how hot it is outside, before messing up Your engine in a daily driver, Flip that Heat & defroster to High when stuck at lights if temp starts spiking badly again?
Radiator boil out is usually $35-$50. if You take in to them, Water pump = $100. & Fan Clutch abt. the same. Condenser Cleaner is $8.-9. a can & Prestone or Zerex Radiator Flush is abt. $8. a bottle. Water's in Your hose and this isn't life altering....probably couple hrs of cleaning & You're going to be fine...I'd stay way from using brushes on radiator fins, condenser fins or trans cooler fins; just cleaner, then wash off w/water, 2-3x let it dry & compare to Your picture. same for radiator flush. We've all seen all kinds of 'gunk' come rolling out radiator drain doing flushes & that crap was clogging Your coolant channels in block, clogging up radiator, & generally stopping flow, everywhere. Be sure to have heater on when doing flushes & follow directions exactly. When done, You' should be able to notice even under hood that it's running cooler; turned off, drain out all the water, close radiator drain, add coolant back in & You should be fine. Dirt is the enemy of airflow. Whether filters or intakes or cooling systems, they have to be clean to work well.
HTH's?
