Troubleshooting brake problem...
The residual valve is located in the MC. The one under the MC may be a metering/proportioning valve. The residual valve is supposed to keep 10lb of pressure going to the rear drum brakes. If it's not there and the first push on the pedal will go mainly to the rear wheel cylinders, IIRC. I think there is a good write up in the tech links.
Here is the link...http://www.mpbrakes.com/troubleshooting.htm
The master had a new residual valve.
I fixed the little bugger :)
Both cylinders need to be adjusted and both fronts were so tight, I thought they were one piece. You can't see in the pics but it took all my weight on both of them to get it to break free with about 3' of leverage.
The pads have almost no wear but they aren't quite matched to the curve of the drums. I left 'em a bit tight so I can wear them back to normal. High speed panic stop vs. pumping up the pedal is the same stopping power now. Pedal height is about 3" lower if I let it sit but I still am a long ways from the floor. I can stand on it and it will stay put as well.
Thank you all for the help.
I know that this is going to sound crazy but I would go back in there and coat those threads with a no lock treatment of your choice. That way adjustments will be easier in the future.
Follow up:
I had (have) three problems.
1st: The master was bad. If I held the pedal after pumping it up, the pedal would slowly go to the floor. New master fixed that problem.
2nd: The rear pads were not adjusted. There is a 10# residual valve that keeps the rear pads against the drums. You need to have the cylinders adjusted so that the pads are seated against the drums and then back off a few notches. You should be able to spin the tire one full revolution before it stops. Any slack here and you will have to pump the pedal to get the pads to seat. The residual valve can hold it for a little while but if you find that brakes are good then after being idle for awhile, you have to pump again, this could be the problem.
3rd: The older drums have 2 cylinders per wheel. The newer have 1 per wheel. I have the older style and I took my axles apart to paint them. When I rebuilt them, I didn't realize the left cylinders are different than the right (driver's side vs. passenger side). The cylinders have right hand threads on one side and left hand threads on the other. If you get them correct, the action of pressing the pedal will adjust the rear pads against the drums. Get it wrong, and they adjust away from the drums.
4th: I'll add a fourth one.....any air in the lines and you have to pump the pedal up to get the pads to stop the truck.
quit screwing around and put some vise grips on the rear soft line and step on pedal , if it still takes a pump for it to get tight then put vise grip on front soft line and test again to determine which end of truck is having issue . if problem persits after both lines are vise gripped then prob. is at booster or master. If you determine there is a prob. in front or rear then you at least know where prob. is .
Are you adjusting brakes with tires on and tight?????? do so if not. My drums actually ran hot for a couple days because they were adjusted so close but they had good pedal 1 push and wore in just fine , fter 1.5 years upon disassembly for disc in front all drums , pads , surfaces looked killer . Oh yeah , take it outa low range , the brakes won,t stall or even stop it if you are in low and 1 st.
I admit...I was focusing on the rear brakes. I think....the rears were doing about half the work until my front brakes failed. I stared looking at the rears because I could no longer stop as well.
Here is what I found when I went to replace the front pads. The tire had about a 1 1/2" rock top to bottom and both nuts were laying as you see them in the pic. The rotor had been ground down on one side to beyond spec. I swapped all the parts over from the parts 60 and the brakes are better than ever.
and no....the alen wrench was not the problem. ;)
