Troubleshooting ABS error - debris on sensor tip
boston
Hoping someone can help resolve an ABS error on my ’06 gx. I switched out the Cv axles and consequently both speed sensors (after market). Front left no issues, but front right I’m getting a debris on tip of sensor error. When I clear the code and drive the abs engages at low braking speeds and then the light comes back on and the system shuts off. Removed the axle and cleaned the hub and sensor with no luck. Tried another new sensor no luck. Replaced the wire harness no luck. Removed the sensor to see what errors I get and it's just a general front right circuit abs error with no debris error. Kind of at a loss. Anyone have any ideas on what I can try next? Any chance this is an alignment issue?
Did you strain the ABS wiring at all? There may be a break in the harness leading to the ABS sensor. If that checks out, it could very well be the aftermarket sensors. Since you didn't mention it, what sensors did you buy?
