Troopy part number validation
Hello all,
I am trying to find Troopy (1998 HZJ75) parts here in the States. The local parts guy is being very helpful, but of course his catalog does not cover this vehicle.
I think I have most of the part numbers sorted, but sure would appreciate confirmation from anyone who knows better...
Some of the posts here have mentioned a database - is it on IH8MUD? Where? That would be great and I would be happy to add...
1) front & rear spring bushings - 24x 90389-18002?
2) left front brake caliper - 47750-35080?
3) left front steering knuckle - 43212-60090?
4) left rear brake caliper - 47750-60110 (add -84 for remanufactured)
5) front sway bar bushing kit - ?? anyone know ?
Thanks much,
Chris.
I've done a little research as I am possibly working another 70 series truck myself. Some of the later model 70 series stuff is the same as the 80 series parts.
I have an 85 Bj70, and many of the brake parts are the same as the 60 and 62 series. :meh: The knuckles, I'd have to take a closer look, but they looked pretty close to the large pattern knuckles and arms. It may be the same for the later model 70s and the 80 series LCs
Thanks guys. I should have been more clear. I have consulted offroadshop.com.au and ToyoDIY and downloaded the EPCs (which was a huge hassle and didn't give me anything beyond what is available on ToyoDIY).
Does anyone else have a good Australian site, besides offroadshop.com.au, for part number validation?
Here's where I got the numbers I listed:
1) front & rear spring bushings - 24x 90389-18002 - all sources agree, so I believe this is correct. I confirmed last night that all 24 bushings are the same size.
2) left front brake caliper - I could not find anything on ToyoDIY, I was given 47750-60021-84 by the local dealer but found 47750-35080 on offroadshop.com.au. Of those, I trust offroadshop more.
2.1) I just re-read an IH8MUD thread and realized I probably should also get the rebuild kit ("pins, or rubber boots for the pins or mount"). Anyone know the rebuild kit number offhand?
3) left front steering knuckle - I was given 43212-60050 by the local dealer and got 43212-60090 from both ToyoDIY and offroadshop.com.au.
4) left rear brake caliper - 47750-60110 (add -84 for remanufactured) - number from offroadshop.com.au, partially confirmed by this thread: https://forum.ih8mud.com/80-series-tech/198213-caliper-part-numbers.html
4.1) I just re-read that thread and realize I probably should also get the rebuild kit ("pins, or rubber boots for the pins or mount"). Anyone know the rebuild kit number offhand?
5) front sway bar bushing kit - I did not realize I needed these until last night, so I haven't checked with the dealer. I cannot find on ToyoDIY. Anyone know offhand? I found this on SOR: Specter Off-Road Land Cruiser Parts - Page 102 Land Cruiser Suspension
Finally, some IH8MUD thread have mentioned what I assume is an IH8MUD database for parts. Is there such a beast?
Thanks much,
Chris.
Ok, some progress...
I have confirmed that 47750-35080 is correct and that a rebuild kit is not needed.
This I am having trouble with. ToyoDIY, and others, say 43212-60090 but this is listed as 'discontinued' by my local dealer and SOR.com does not stock it either. My dealer can get 43212-60050, which looks identical in that all the parts that appear to attach directly to it are the same part numbers (based on diagrams). Does anyone know if 43212-60050 can in fact be used?
I have confirmed that 47750-60070-84 is an available alternative for 47750-60110-84 and that a rebuild kit is not needed.
I can get some of the bushings but not all. 90948-01003 (8x) is available, but 48815-60020 is not (diagram below).
Anyone know an alternative for 48815-60020? That 48815 sure looks like a common part... I have seen some IH8MUD posts on it, I think...
The calipers... go to Napa and get an FJ60 caliper and a 4Runner V6 calipers. I bet it is going to match one of those. The 4Runner calipers are a larger piston bore and are a bolt-on upgrade for FJ60's (though, you then need the 80-series master).
The spring bushings: measure the ID/OD and match it to what SOR has. They list their bushings' sizes on their site.
Sway bar bushings: FJ60/62 will work for the that. Although, if the diameter of the bar is different, then front two bushings that bolt to the axle won't work. In which case, measure the diameter of the bar and compare to say... FJ80 or FZJ80.
Try the following part number for the sway bar bushing: 48815-60070. That should work. Those are for the fronts of an 80 series sway bar from 8/1992-1/1998. You might also try: 48815-30080 which is for the front of an early 80 series: 1991-1992.
43212-60050 is a legit part number and is the LH knuckle from 1980 up through 1990 (so, FJ40/60/62).
Good luck.
Pretty sure the knuckle is different from a 60 series, the HZJ/FZJ75 uses a high pinion front diff with CV joints in between 60 and 80 series in size and uses a unique swivel hub kit to that model. Brake calipers are also different from 60 series, have a look in Zoltans thread, there are pics of the knuckles and calipers in there.
the later HZJ78 and HZJ79 went to coils and used the 80-series front diff (housing is exact) but with different hubs (knuckles are same, but the wheels hubs/rotors are different which is where the wider stance from 80 series comes from) ... but the HZJ75 had a leaf front end with the (edit: boy was I wrong... it's an 8" third member HP) full size 9.25" axle; nearly identical to 60 series (though the housing is different.)
Leaf spring bushings are available through your local Toyota dealer. They are about $5 each.
The 1995 HZJ75's have a conglomeration of 60 and 80 parts. I had to combine parts from an 80 series kit as well as a 40/60 series kit to do a knuckle rebuild on my 1995 HZJ75.
I can't remember what I used out of what, but I do remember that the inner axle seals are definitely an 80 series.
Thanks all. I was able to locate the correct knuckle (43212-60090), new from Canada. And I will just go ahead and try both 48815-60070 and 48815-30080 for the sway bar bushings.
Cheers,
Chris.
One last question for the great collective wisdom... (and many many thanks for the help thus far!)
ToyoDIY says that the inner seals for the troopy knuckle (43212-60090) is 43204-60041. That number does not show up in the local dealers system.
GreaseCruiser, you said "inner axle seals are definitely an 80 series", which seems to be 43204-60031, which is available.
Can anyone confirm whether -60031 can be used in place of -60041?
Thanks much,
Chris.
Thanks much,
Chris.
43204-60031 are the wiper seals (felt/rubber/metal and the 2-part half moons) that go on the back side of the knuckle ball. Those are the ones used on the 80 series.
The inner axle seal, if it is indeed an 80 series seal, is 90310-35010. Any Toyota dealer either stocks these or can get them for you reasonably easily. They are about $9 or so.
Part numbers
Hzj 75 part numbers inner axel seal 90310-35010 [same as 80ser] sway bar bushes 90948-01003 x8 . D mould bush 48812-26020 x2. Swvil hubs are different to an 80ser. Seal kit for 1 side is 43204-60041. Kit for both sides is 04434-60031. Hope this helps.
Another question on part interchangeability. Do the hoods on the 2000-2006/7 70 series swap put with the pre-98 trucks? I am contemplating a new hood for my troopie, and when I take in consideration finding a used hood and most likely shipping from Canada, for a little more I can get into a new hood:meh:
They look the same, but there are a few different part numbers for the "old style" hoods.
53301-60151 is the p/n for my '97, not in us system, runs up to MY 2001
53301-60380 is the PN from 2001 up to 07 when the body style changed.
Will the new hood bolt on?
Sent from my interwebz doo-dad
