transmission woes
Houston TX
97 LC all stock
I am having a problem getting the transmission to work in drive. When drive is selected the dash lights indicate that the gear selected is Low with the D selector being lit slightly dimmer as if to tell you that I know you want to go into drive but I am not going to let you. I have attached some poor quality camera phone photos. The first shows the dash indicators when the shifter is in drive and the second shows the indicator when in neutral. If I attempt to drive the vehicle it doesn't leave the low gear. I can put it into 2nd gear and it will work in 2nd. The transmission fluid levels are fine and the fluid does not smell burnt. Another funny thing is that when I place the shifter in low the D indicator is dimly lit just as it is when the shifter is in drive??? any ideas?
Thanks a bunch,
Duane Ferrell
