Hi there,
I've been a bit of a long time lurker on this site, and have finally gotten my grubby mits on a 96 FZJ80 with 107k miles on the clock. I have had it for about two months, and apart from the front diff lock not working i'm super stoked with it.
However in the last couple of days i have been having a bit of an issue with the transmission. Basically what happens is when i accelerate gently from a stand still i am experiencing a light shudder. If i accelerate hard then it doesn't happen. Also when i put the shift lever into "D" with my foot on the brake the revs seem to drop more than normal and it almost seems like the engine wants to stall. Almost like when you are driving a manual and you let the clutch out and don't give enough gas. When in "N" it idles bang on 650rpm and doesn't budge. I have LPG installed and have run it both on LPG and petrol and it does the same. Revs smoothly in N and D (with the brake applied) so i'm ruling out any kind of misfire.
I have read all the threads i can find on here about adjusting the throttle cable and shuddering transmissions, but they all seem to be shuddering when accelerating hard as opposed to gently and whilst at speed. I did try adjusting the throttle cable, but that didn't help. I just ended up with a harsh shift.
Also the PO had the ATF changed at 100k miles. I have checked the levels when the engine is warm, and it is above the "hot" mark, but i have already done 2k miles in this truck since i bought it and it hasn't skipped a beat until now. The fluid doesn't smell burnt and still looks clean.
Any clues as to what my issue may be?
Cheers
Thomo
Cheers
Thomo
