transmission TC lock
Denton, Texas
I have a 97 LC with 208k miles on it. Kid hauler.
Lately I have been dealing with the transmission hunting for TC lock at the 2000 rpm and 48-52 mph range. Light throttle (tp at 20-25%) Once I get to 60 mph the TC will lock and I don't have any problems.
I don't think it is a transmission problem. No ODBII codes for transmission. Tranny fluid is topped up and fresh.
I think it is a direct result of my recent intake/VCG repair. I have made adjustments to the throttle cable from the transmission to the throttle body. I have adjusted the TP sensor back into spec (it was off by 1% when throttle was closed). (I have also redone my upper and lower oil pan seals.)
I have not done a complete diagnosis on the TPS yet or the wires from the ECM.
I have one wire that got its insulation chewed up by a rat, the 5V wire from the ECM. I have wrapped it in electrical tape.
When I do a live data watch for the TP sensor, it does not flutter when the truck tries to get into TC lock. It holds steady.
So I am asking for some input. I plan on checking out the connection at the transmission and the TPS sensor. One person suggested that I recheck all of the vacuum lines that I touched.
Anyone else experience this? Any suggestions would be appreciated.
Well I have to edit my symptoms. It will slip in and out of tc lockup even at speed greater than 55 mph. It really seems to be dependent on throttle position.
Tps sensor passed basic resistance test and ECM is providing 5v.
Checked for loose connections at the tb.
On a hunch, I read that the TC lockup is controlled by the ECM using the VSS on the transmission and the brake light switch at the brake pedal. So I put some foam on the pedal stop and drove it around. It worked great for about 2-3 days. Then symptoms re-appeared.
Got a new brake switch, return spring and stopper installed yesterday. No symptoms for the last 20 miles.
The old switch seemed a tad looser than the new one. Also the pedal stop had a groove in it from the switch button. The pedal return spring looked ok, but I wanted to be sure I fixed all variables for that switch to work correctly.
Update:
Rebuilt the transmission. No change :bang: Granted, there were alot of worn parts. And I plan on keeping the rig for the long haul.
Out of dumb luck, I was messing with the intake manifold and realized that my EGR pipe to Valve was not screwed down tight. Fixed that and now issue is gone. :beer:
