transmission shift problems
San Diego, CA
I'm almost afraid to ask. I have a 93 with 237,000 mi. on it. When I manually shift the truck into 1st gear it seems to start in 1st but then it shifts into 2nd, then holds 2nd gear. When I slow to a crawl, it harshly shifts back into 1st. I've played with the detent or shift down cable with no improvements. Was hoping someone had an idea.
Check fluid level
Maybe replace fluid ?
If you manually shift it to L and the dash repeater also says L and it feels like you put it in 2 then your 1st gear band may have failed.
IMO not something to freak out about. It is repairable but will require trans disassembly.
If your early truck doesn't have the dash repeater light, you will need to verify that the trans is actually shifted into L before further diagnosis.
My 96 is doing exactly the same thing, did you ever find a fix.
