transmission question
Atascadero, CA
i am wondering if someone could tell me if an early five speed toyota tranny will bolt up to a land cruiser transfer case. i have a land cruiser four speed right now and i have a sbc 350 with a downey bellhousing. i am trying to find a new transmission because mine is going downhill fast. i want one to be as close to direct replacment as possible. also will this work wiht my motor and bellhousing setup? are the transmissions the same spline? thanks for any info
-miles
no you will need a split case to bolt up an h55, you will need on out of a non-usa truck that has the parkingbreak on the output shaft. I saw one sitting on the floor of marks (65swb) shop like 1mo ago give him a call
You may want to do some research before you buy an H55 w/ TC. There are 2 potential drawbacks. First, some split case TC's have pretty high gearing in 4Low, see the following link: (http://www.off-road.com/tlc/faq/trans.html#HD_NM_5). Second (also check the link), the H55's 5th gear/OD only gives a modest 15% reduction in RPMs.
Both numbers are pretty underwhelming considering the cost of the conversion to an H55. Looks like you might be able to correct both gearing issues with a Marks TC gear set, see option #2
(http://www.marks4wd.com/lc-extra-low-tc-gears.htm).
The gearset is about 1300 USD + tariff and shipping. Don't know what a TC rebuild would cost.
Hi All:
I think you guys are missing an important point, he does not even know what model of Toyota five speed transmission he has access to.
If the five spped is from a Toyota HiLux it will not work with the Land Cruiser bellhousing nor the TLC Transfer Case. If he is in North America, the H55F is not a particularly common transmission.
The easiet replacement for a TLC four speed is another TLC four speed. You should be able to find a good, used one for $100-150.
Good luck!
Alan
" an early five speed Toyota tranny ".....From a mini?
No, it will not work with your current transfer case, or bellhousing/cluch set up.
Then your best bet would be to post up in the wanted section that you are looking for a good four speed tranny, it woud also help if you post up what tcase you currently have, as there are a couple versions of the Toyota Land Cruiser four speed tranny...16 spline tranny output shaft, used with the earlyier one-piece tcase, and a 19 spline output used with the split cases found in 40 and 60 series after 08/80.
Install one of these and be done with it.
Good luck!
-Steve
