Transmission question
St. Louis Area
Greetings:
I have noticed that when I put her in drive immediately after starting the engine, I apply gas to the pedal, the engine will rev but the truck will crawl away from stopped position. Once moving it will eventually act normally within a few hundred feet.
However, if I start the engine and wait a few seconds for everything to get up to preasure before putting it into drive, then everything responds as it should. Tranny fluid has been changed on a regular basis. (drain and fill).
Does this seem normal? Any thoughts?
Thanks,
Steve
94' 215,000
