Transmission Problem
Calgary
Hello,
I have an 1990 HDJ81 VX with an automatic transmission (A440F I presume) and 170K on it. Yesterday the third gear and reverse started to slip pretty bad to the point I had to drive back home in second gear.
I looked in the book and these symptoms seems to point toward a faulty "rear clutch". Anybody experienced this and what would you recommend next?
Thanks
Andre
You may have an A442F (electronic controlled; if you have an overdrive button or a "power" button, that's what you've got), in which case there could be codes to pull; for example, the problem might be a faulty solenoid.
Regardless: Check the fluid level as per the FSM, drop the pan, inspect and clean the filter.
Curtis
Your transmission code should be written on the sticker on the driver's door jamb. That's about all the help I can give you ;) Good luck!
