Transmission lift?
Colorado
I picked up a Toyota DC drive shaft at the pick and pull for $18 and got it retubed and balanced for $96. I only needed to re-drill the rear axle flange to make it work. I also built some adjustable rear control arms and installed a 1.5 inch body lift.
With these mods, I now have the ability to raise the transmission so I can tuck it up further out of harms way. In its stock location, it seems to be begging to get damaged.
Does anyone see any reason not to raise the transmission mount 1 inch. It will effectively move the rear output a littler over 1.25 inches. I can then install a cross member under the tranny output flange and build a belly skidplate from this cross member to the transmission mount cross member.
The only hiccup I can see, is maybe the radiator plenum, but I have yet to install that after the body lift. I'll modify it as necessary before summer comes.
Also, I'll pick a DC shaft this week and have it re-tubed to replace the front driveshaft.
Thanks,
Adam
Are you talking about moving the tranny, tcase, or both?
I've often wondered why people don't do this myself.
Yes, just a 1 inch shim between the crossmember and the transmission mount.
Adam
Er, you didn't really answer my question. So you mean the cross member for the t-case?
Yep. That one.
Adam
Let me know how it works for you and what it effects. If it works well, I'll probably do something similar.
Toyota DC driveshaft... what are the differences? I did some searching and got a ton of hits. I am looking at options for a DC shaft.
