transmission kickdown cable adjusment ??
arizona
Website
www.roamingazexpeditions.com
I seen a link a thred in here that some one did a adjustment but now cant find it :bang:
heres my problem, does it sound like a cable adjustment issue or should I take it to the trans shop?
shifts ok starting out from park , no hard shifting kinda slow tho
When I get on the freeway I can get up to 60 or so but I have the skinny pedal floored and it does nothing, it should downshift.
When I adjust the cable , do I just tighten untill tight, right now it feels loose.
They dont like to downshift very easily, the cable adjustment will help. Mine was very loose also, make small changes to it, and test drive. It should also help with shifting through the lower gears at slower speeds.
Okay, I too decided I needed this adjustment on my '92 FJ80. I guess from the pictures on the FAQ that the FJ is set up slightly different than the FZJ. However, I adjusted the one with the red stopper that went down to the tranny. I doubt I messed up there. But.... the FAQ said that it should be about "1 millimeter out from the stopper..." Well, that didn't cut it in mine. I took it until it was tight and there is now about an eighth to quarter inch between the stopper and the little swage on the cable. It seems to be much better. Before it would surge a bit upshifting which wasn't too bad, but coming up to lights and slowing down sometimes it would wait to downshift it seemed too long, then kind of take up slack so to speak and bang a bit. Doesn't do that anymore but the spacing on the cable deal doesn't seem right according to the FAQ and I don't want to mess it up. Am I just paranoid, or is that just some sort of difference between the FJ and FZJ?
You did fine; that cable stretches a *lot* over the years.
It's pretty nice having the shift points back where they belong, no? :cool:
Cheers,
Curtis
Ha ha. Oh yeah.... very nice. I will mess with it a bit more as I drive over longer distances. I didn't realize how easy it would be to get it there. What about the cable from the throttle going to the cruise control module? That one was even looser. Should I adjust it too? Maybe thats why my cruise won't work. : ).
I wouldn't worry about that one; mine has quite a bit of slack as well.
Do you want your cruise control back? That's a separate issue, but one we can certainly figure out.
Curtis
I have also noticed since adjusting that the low idle is slightly higher, before i was around 450rmp, now its more like 500-550, and much smoother
It sounds like you overtightened the throttle cable a little bit, same as pushing the pedal slightly. Your idle is still a little low - have you tried to pinpoint the problem?
it doesnt look to be overtightened, there is still a little slack, it was just very very loose before. No, i havent worried about my idle being in the 550rpm range.
After fixing my y-pipe leak (https://forum.ih8mud.com/80-series-tech/294160-how-repair-cracked-y-pipe-p0420.html), and replacing my fuel filter (https://forum.ih8mud.com/80-series-tech/294212-coffee-anyone.html), a quirk I had became more pronounced with the returned power I gained.
Under load (normally going up hills), when my cruiser would get near a point that it might down shift, the RPMs would drop slightly (50RPMs or less), and then climb back up. This "reverse surging" was really annoying to me, although not really noticeable to passengers.
I adjusted the cable slightly at first and it didn't make much of a difference. If anything, it got slightly worse. I adjusted a few more millimeters until most all of the slack was gone, but the cable was not tight.
Problem solved.
:cheers:
Nick
