Transmission Help
Elko, NV
I found a 2001 or 2002 Chevy 5.3L Vortec Engine. I am planning on putting in a 4L60E automatic transmission. Was wondering if I needed a 4x4 or 4x2 transmission. Also, was wondering about problems that will arise with this install and also any adaptors that will be needed to complete the job. Your help is very appreciated. :cheers:
Sorry about the question:doh: . I did some research and found some information that is going to be helpful. From what I gathered I will need the v8 motor mounts (standard v8 mounts or vortec gen III mounts?), rear crossmember mount, adapter for 4l60e transmission to transfer case, and the front transfer case output flange. Also still confused on what type of transmission I need? I think on another site it said I would need A 4x2 4l60e transmission for the different output shaft. Would I also need this adapter it is a transfer case linkage bracket. Any other info will be appreciated.
