need help, my 80's manual tranny growls and jerks when left in gear ( 1st, 2nd and 3rd), It jerks as if it hesitates and growls like there is something loose gear inside the tranny when i let off the accelerator and clutch pedal and let it crawl on its own. I put 90w grade gear oil and noticed that when the oil heats up it looses its viscosity and becomes noisy, i changed the oil to a grade 140 with a gL-4 rating thinking that it will make it more quieter but after driving it for an hour i noticed that the growling sound is still there. The "growling sound" only happens when its on 1st 2nd and 3rd gear specifically when decelerating and when i let the truck crawl.
a mechanic told me that maybe the input shaft bearing needs to be replaced???
what gear oil should i use to lessen the growling sound? will a 75w-90 gear oil do the trick?
.a mechanic told me that maybe the input shaft bearing needs to be replaced???
